| | | Forums66 Topics128,139 Posts1,056,754 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 | I while back I switched out the Rochester on my 60 235 with a Carter YF 2101S. The switch was strait forward with the exception that the intake manifold studs are a little to long, and without a couple of extra gaskets the passenger side stud comes in contact with the carb body.
So my question, should/can this be solved with a carb spacer or do I need to replace the intake manifold studs? If a spacer, maybe someone has a vender source?
Thanks much,
-Chris
1953 Chevrolet 3100
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Do you have the spacer installed? | | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 | I had no spacer under the Rochester, just a gasket..Should there have been one?
1953 Chevrolet 3100
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Yes, and they are available from all of the vendors. | | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 |
1953 Chevrolet 3100
