0 members (),
135
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | My truck has some sort of attachment on the outside of the bed in the first panel left side. It has a small little bracket on the top but it's hard to see how it held anything. Does anyone know what it was used for? There's a couple photos here: What's This? Some other clues to the possible use of the truck. There were 2 holes about 1/2" dia. & about 4" apart in the back of the cab on the curved part between the left door and the back glass. There are also 2 holes (filled with screws now) in the dash. Does this suggest a radio antenna in the back with a dash mounted mike? I'm guessing the holes in the header panel was for a sun visor but I'd like to know if someone has seen these in another truck also.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have no clue. Good luck...
~Jim
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | probably right about the radio stuff, maybe the fire chiefs truck ... and the bed wall dealie was prolly for some kind of emergency markers, especially from the yellow paint showing
Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have seen similar brackets that hold road flares/Kerosene pots in that place, they slide down into the "V" and the little latch keeps them from popping out. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Harold, The first and the last photos are of a bracket that held a stack of 3 breakdown lamps/lanterns,that were probably of the oil or kerosene style that used a wick like a Coleman Lantern. You stacked them one on top of the other and pushed the tab on top down to lock them in place for storage. Regards, steve sr. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Sorry Brad, was busy typing,or should i say 2 finger hunt and pecking while you were also, steve sr. | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Thanks Brad & Steve, Does that indicate that this truck might have been some kind of service truck? Forgot to mention but probably not relevant the original color was blue.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Harold,
It could be. I bought a '49 1/2 Deluxe 5-window a couple years back that was a Union Pacific service truck and it had one in the same location. They pop up on eBay from time to time often NOS. I have a GMC Parts Book (Light-duty) 1939-1953 that has a picture of them in the Accessories section 22.0800 it shows the vertical storage like you have (PN 2233073) and also a set in a box that would go in the cab (PN 2233294). | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Thanks Brad,
Maybe I'll check E-bay more often. Might be a neat accessory.
| | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I don't know, but to me it looks similar to the emergency markers similar to what would be Stevie T's factory-original emergency marker bracket. Different series, but similar form/fit/function to my eye. Bill | | |
