1 members (Hotrod Lincoln), 74 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#84051 10/11/2007 12:44 AM
I am replacing the stock axle in my 57 3100. I have all 8 nuts off the U-bolts, and the forward u-bolts out, but I can't seem to seperate the rear u-bolts from the curved shackles. They look like they should come apart, but after several blows with my heaviest hammer, no dice. I even thought the angle might be pinching the shackle or something, so I moved the axle up and tried again, but no luck. Tried a search and didn't see anything. Anyone?
Thanks!
Dan ohwell
my truck gets better every day...every PAYDAY smile
#84052 10/11/2007 2:00 PM
Riding in the Passing Lane
I take it you are referring to the lower support bracket. They get rusted in pretty good but if the front came out they shouldn,t be to far away. If you have a torch some heat would loosen it up. If not some spray rust loosener & a big hammer is it. You are probably going to replace the u-bolts so hitting them on the ends is ok.
1972 Chevy c10 Cheyenne Super
#84053 10/11/2007 5:29 PM
If Im thinking about this right, can you put the frame on blocks, and jack up the rear end so that the leaf spring pressure pushes them apart?
Im sure I wont earn any points on safety here...
My 1953 Chevrolet
1947.1 Gallery
#84054 10/11/2007 8:47 PM
The leaf springs are bolted together. You can put it on stands & lower the rear end. That may help.
#84055 10/14/2007 4:59 AM
Well... i went to Harbor Freight tools today and purchased one big 'ol punch. I got the rear shackle/u-bolt undone on the passenger side by prying the ubolt upward with a giant prybar. I got the drivers side undone with the punch resting on the top of the shackle and hitting it repeatedly with the bf hammer smile on a side note, I bought a sandblaster and some medium SiC blast media. After I got her together, it didn't take long to get the cowl panel, upper valence and some misc. small parts looking new again! This site is awesome. Thanks for all the help so far!
Dano
