5 members (klhansen, dt235sd, thekid1950, Hotrod Lincoln, RoadsScholar), 176 guests, and 1 robot.
Topics128,080
Posts1,056,064
Members48,433
#839903 03/30/2012 2:45 PM
I have just bought a vintage camping trailer which has split rims and 7.50 X 16 tires: I am hoping that some old guy here could tell me what that tire size is in modern numbers. I had done a search online and found a couple of places telling me it is 235-85 16, but this is very wrong (I have tried!). My tires are 31" diameter.
Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
wave1957 #840011 03/31/2012 12:32 AM
I'm going to my local tractor tire dealer tomorrow morning. My tractor has 7.50 x 16 tires on the front. I'll ask them about yours.
1939 Chevrolet Stake Truck
rickmg #840014 03/31/2012 12:41 AM
Are you thinking about replacing them with radials? Replacing the split rims too? That size tire is still available in 8 or 10 ply bias. Your old trailer will love 'em.
Professional Novice
Frank50 #840020 03/31/2012 1:08 AM
Yes, I will get rid of the split rims too. It sounds like you are saying that these tires would be better than radial, is this correct or are you just curious? I know this tire size is still available, but knowing the modern size would give me more choice.
wave1957 #840107 03/31/2012 1:13 PM
I'm not saying bias is better than radial, but bias tires are still in wide use in lots of applications...
Power King brand has this ST7.50-16 trailer tire
http://www.powerkingtires.com/Tires/Trailer/ST%20Bias/308
and this ST235/85R16 tire
http://www.powerkingtires.com/Tires/Trailer/ST%20Radial/318
that seem to be comparable. The radial is almost 2" wider section and requires a 1/2" wider rim. Is that what you found: too wide to fit?
Try yokohama. I know they did make/sell a 7.00R15 narrow radial and maybe they make a 7.50R16...
Professional Novice
Frank50 #840400 04/01/2012 5:52 PM
My tractor tire store suggested going to more modern rims and getting away from the split rims. Other than that they weren't very helpful. For radials they suggested LT235/85 R16.
