| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | I have just bought a vintage camping trailer which has split rims and 7.50 X 16 tires: I am hoping that some old guy here could tell me what that tire size is in modern numbers. I had done a search online and found a couple of places telling me it is 235-85 16, but this is very wrong (I have tried!). My tires are 31" diameter. Thanks!
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I'm going to my local tractor tire dealer tomorrow morning. My tractor has 7.50 x 16 tires on the front. I'll ask them about yours.
1939 Chevrolet Stake Truck
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Are you thinking about replacing them with radials? Replacing the split rims too? That size tire is still available in 8 or 10 ply bias. Your old trailer will love 'em.
Professional Novice
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Are you thinking about replacing them with radials? Replacing the split rims too? That size tire is still available in 8 or 10 ply bias. Your old trailer will love 'em. Yes, I will get rid of the split rims too. It sounds like you are saying that these tires would be better than radial, is this correct or are you just curious? I know this tire size is still available, but knowing the modern size would give me more choice.
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | I'm not saying bias is better than radial, but bias tires are still in wide use in lots of applications... Power King brand has this ST7.50-16 trailer tire http://www.powerkingtires.com/Tires/Trailer/ST%20Bias/308and this ST235/85R16 tire http://www.powerkingtires.com/Tires/Trailer/ST%20Radial/318that seem to be comparable. The radial is almost 2" wider section and requires a 1/2" wider rim. Is that what you found: too wide to fit? Try yokohama. I know they did make/sell a 7.00R15 narrow radial and maybe they make a 7.50R16...
Professional Novice
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | My tractor tire store suggested going to more modern rims and getting away from the split rims. Other than that they weren't very helpful. For radials they suggested LT235/85 R16.
