7 members (Gdads51, Cletus1950, cmayna, 55shaker, 3800GUY, Gray_Ghost, FAST55),
145
0
Mod | | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 27 | Were rear bumpers an option in 1958 or were they a standard item? | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Story I'm told is that they were only an option. No such thing as a "factory" bumper in '58. You got them at the dealer or aftermarket.
Bill | | | | | Joined: Nov 2010 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 27 | Thats the same story I have heard, Thank you | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That is correct, the rear bumper was optional. Most were dealer installed, with many being aftermarket, rather than GM. I've seen several different styles, Winchester (yes, the gun company) and Bardon (?) are the 2 I see the most around here. There is an RPO code for a rear bumper, RPO 218, so it is possible that at least some trucks did have a bumper installed at the factory.
Bill Burmeister | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | I do believe that you could get rear bumpers installed from the factory, but it was an option and cost more. Jim
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the rear bumper could have been ordered as a factory option from 55 onward, and could have been purchased from dealers as well Bill | | | | | Joined: Nov 2010 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 27 | Thanks for all the help!!!! | | |
