| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 6 New Guy | | New Guy Joined: Mar 2012 Posts: 6 | ive pulled the old 327 that was in my 58 napco and discovered why it was parked(hole in the block) so thats junk...after cleaning the engine bay(6 buckets of crud)im repainting the bay black as it should be...my question is can i take high heat paint and repaint the rad or do i need a special rad paint? ill send before and after pics of what i think and engine bay should look like! | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Try reposting in a different section?
| | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Don't think it necessarily has to be hi-heat paint. if you use a good etching primer and a good enamel paint (I use krylon in the can) by Sherwin-williams, it should work fine. Good luck!! | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Radiator black paint from Eastwood: LINK
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | Any black paint will work for a radiator as long as its not real heavy. I find the $.99 store brand of flat black works really well for radiator fins, and a better brand of semi gloss for the tanks. As for the frame and such, any of the better brands will work as long as its grease and oil free.
Joe | | |
