2 members (Otto Skorzeny, 1 invisible),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 18 | My plans of updating my '57 LCF, 2 ton is.... I want to use a new 350 Goodwrench motor, Auto Trans., and use the original rear-end. My question is....What auto. trans. would be the best to use???
Am I thinking right by using the 350, Auto. Trans., and locking the rear-end in the high side, as I'm never going to have a load on the truck. Any and all tech. help would be great!
Warren L. Seiz Phoenix,AZ
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Due to the very low rear end gear ratio in your truck and the slip of the torque converter of an automatic I would use an overdrive transmission if I were you. Your best bet would be a 4L-80 they are much like a turbo 400 but with a 4th gear overdrive. They can be found in mid 90s to present Chevy and GMC ¾ to 1tons and there are even stand alone computers for the electronic models. In my opinion you would be disappointed in the performance of your truck with t turbo 350 pushing though them low gears. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what Grant says ... the 4L80 is the OD update of the TH400, and the TH350 wouldn't hold up long on a heavy truck
Bill | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You could also put in an Allison automatic. | | |
