6 members (Southerntruck, dt235sd, Gdads51, GMCJammer51, NJC, John L.), 113 guests, and 3 robots.
Topics128,091
Posts1,056,392
Members48,442
#839841 03/30/2012 4:25 AM
1 Offline
Does anyone know where to find & buy either Alcoa or Budd Polished Alum. wheels (6 holes front & rear)?
Also, I want to add power steering to the LCF. What & where would I find a P/S gear box for the old girl?
Warren L. Seiz Phoenix,AZ
You may be able to find some parts that you are looking for on the web-site:http://www://trucksofyesterday.com. I came across this web-site by accident,last night,when scrolling through "classic white trucks.com." They have over 2,000 classified ads posted,parts for sale,as well as parts wanted! a LOT of stovebolts,and parts,parts,parts! I may have a line on a Brown-Lipe 3-speed auxiliary trans. for my '55 2nd-Series 6500! There is a post on the site,where someone has a Stack of EARLY Alcoa 5-hole,(10-bolt),but they look to be 22.5's,not 20's. But you never know. He may have more aluminum wheels in-stock,that are not pictured. It may be worth a try. Hope this helps.
Mo' Tater
1 Offline
Thanks, I'll check this out. Warren
A tubeless one piece wheels will be 22.5". The 20" wheels are all multi piece tube type.
I've seen Alco's on TF trucks and they look good, but they proabaley cost more then the truck...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
1 Size, I led you in the wrong direction..SORRY! Go to "Brad's Classic Trucks,Go to Links,then go to two lane memories. There, you get the same great stuff that we all get soooo much enjoyment and information from,except that it pertains to all vintage trucks (pre-1975),1-1/2-ton and bigger. Look under parts,trucks for sale,and/or wanted. Over 2,000 ads in this site. a lot of engines,transmissions, suspension and body/trim parts available for fellow Bolters! I just had a post on here(Stovebolt.com), a week ago, and the gentleman that I ordered my wheel cylinders from,(Marvin Ribbich),has a lot of ads on this site! By the way,I installed the brakes,and they work great! Thanks,Marv!
Mo' Tater
I just picked up a set of alcoa 22.5 wheels for my 57 lcf. I had been looking since I bought my truck last summer. There are not a lot of them out there and they are not cheap. Alcoa was the only company to make an aluminum wheel for the 6 on 8.75 bolt pattern. They will be the 22.5 tubles type wheels. I do not have any pictures of them on the truck but here is a picture with them in the background leaning up against the wall in my garage. http://rides.webshots.com/photo/2540031890102329435voCTou
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
