2 members (KEVINSKI, 55shaker), 125 guests, and 5 robots.
Topics128,187
Posts1,057,313
Members48,468
I have a 50 1/2 ton
tank still behind the seat
converted to 12 V generator
2 different 12 gauges one brand new.
2 different fuel senders 1 brand new
Trouble has always been that when I power up, the fuel gauge moves from about 1/2 to E.
Even on the bench.
Sender measures correctly from .5 to 30 ohm bottom to top.
Don't know how to test the gauge.
Running separate ground to gauge.
Testing from 12+ to 12+ side of gauge, S to sender center post, ground from sender housing to - battery post and additional - battery to gauge housing.
Always the same result. Gauge needle moves from 1/2 half to E when powered up. No matter where float is.
All suggestions welcome.
Lampo
50 1/2 ton project
Have you got the gauge installed in the cluster? there's a ground connection (a solder blob) between the two terminal posts on the back of the gauge which makes contact with the housing. You need a good ground connection there to make the gauge work.
Sir Searchalot
Sir Searchalot
Good sender? Then rig it up separate from vehicle using test wires and if that does not work, bad gauge. 12V sender? I understand everything you did but "S to sender center post", identify "S".
Thanks for the reply.
I have used two senders, one that was in the truck and a brand new one. Both act the same.
Same with the gauge, one old, one brand new.
S is the wire from the "S" labeled (signal) post on the gauge. Both are alike.
Mix or match, all old, all new, always the same, gauge goes to E when powered, even on the bench?
This is driving me crazy!!!!
Lampo
50 1/2 ton project
OK I GOT IT!!!!!!
Who would have thought the the gauge housing, even the unpainted parts, and the solder blob aren't connected????? Here is NO continuity between the gauge housing and the BLOB!!! Maybe it's just me.
when on the bench, ran another ground from battery -, to "the blob" and "VIOLA", . :>) it works.
Only cost 2 days and 80 bucks in unnecessary parts. Except I did need a new float.
THanks all, finally sunk in.
50 Chevy, back on the road.
Lampo
50 1/2 ton project
