3 members (TooMany2count, 66flea, Nick in Manitou), 315 guests, and 7 robots.
Topics128,158
Posts1,057,025
Members48,460
I have a '54 235 with the down tube broken off of the crankcase ventilator. The remaining part seems very secure. How is that held in?
Ben
Just a push fit I believe, mine just pulled out
Try tapping an old screwdriver between the pipe and the block, once you get some worked inside you should be able to grab it with a pliers and work it out. It might help to spray some carb spray around the pipe, that will help loosen some of the oil and varnish that has built up around it.
If you need a replacement, I may have one.
Bill garvey
Thanks for the tips guys.
Thanks for thr offer billinwisconsin but I have a replacement
Ben
If I'm not mistaken the lower part bolts to the side of the block with a little tab and the top part just pushes in. At least mine does.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
The tab utilizes one of the pan bolts. Top just pushes in.
