2 members (Hotrod Lincoln, Steelonsteel), 76 guests, and 2 robots.
Topics128,090
Posts1,056,376
Members48,442
#826977 02/17/2012 12:22 AM
Well, I got my inner rollers for my 3/4 ton today. I waited on getting a seal, so I could match them to the bearing. (Timken lists 2 different seals anyway, depending on the bearing you use.)
Does the seal ride on the spindle or the bearing spacer?
Anyone have a part number?
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
3B Offline
Hy Whitedog, could you tell us what year 3/4 ton you're asking about, and seeing as how you wonder if the seal rides on the bearing maybe the bearing number as well.
His pictures are of a 1954.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
My original concern was with the thickness of the seal and the new bearing. Upon inspection it doesn't really seem to be a problem. I actually have a new problem though. The old felt seal, absolutely won't fit over the new bearing. The inner sleeve has a slighty larger outer diameter than the old one.
Timken has 2 listings for use with a B46 style bearing; #40973s with an i.d. of 2.093 and a #5756 with an i.d. of 2.062.
I'm going to have to research it more, but I believe I'm going to have to find a seal with a rubber inner lip and not a felt type seal.
"The Fake Truck"
Whitedog,
I have 2 sets of the 1-ton roller bearings, one for each of the two projects I have going.
I, like you, found that the o.d. of the inner race is larger than the original bearings. In addition, the set of bearings I purchased within the last year, don't even have a machined surface on the o.d. of the race. The set purchased about 4 years ago do have the machined surface.
I've measured everything and came up with the following results.
Ball (original) bearing -> race o.d. 2.093 (ground finish)
Roller bearing set # 1 -> race o.d. 2.153 (ground finish)
Roller bearing set # 2 -> race o.d. 2.157 (rough surface)
Both of these roller bearing sets are manufactured by MBS bearing in Japan who seems to have a good reputation. MBS Bearings, Japan I think they are the only ones producing these bearings.
I found a table of seal clearance guidelines and for anything under a 4" shaft, the clearance was +/- .030". There is clearly a problem with the o.d. of the bearing race.
The bearings with the rough surface are simply unusable. Seal manufacturers are very clear on what is a smooth enough surface. i.e. smooth with no tool marks
I may be able to find a seal with a 2-1/8 (2.125) shaft diameter specification that would work for the bearings with the finished o.d. surface.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
How ironic this is. I have my inner bearing and vernier caliper in front of me as we speak. I was literally scouring through the Timken catalogs. I just came up with seal # 476535.
2.125 shaft
3.154 OD
.375 Width
Rock Auto has them for $10.63
I already have the 40973s seal, it seems like it'll work. If not I'll get the other.
I also came up with a Timken brand bearing that may be interchangable. It'll require a 9/32 thrust bushing behind it though. Right now it looks to be about 1/2 the price as the MBS. I'll have to see what the bushing will cost though. It may not be economical.
Chris
"The Fake Truck"
Following your lead I found another couple that may work in the Timken catalog.
55X80X8 & 55X80X8V
Different seal material & slightly different seal design between the two.
Maybe not so far up the creek after all.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
That Timken site is awesome! There's literally everything you need there to cross over a bearing.
For a tapered outer wheel bearing I have a 1280/1220 combo. The dimensions are identical the b45 outer ball bearing.
For the inner b46 I get:
27880/27820 and 27881/27820 combo. Like I said before, all you need is a 9/32" thick 2" ODx 1.5 ID thrust bushing to make them work.
These bearings are already in production too. The 27880 was used on 46-52 Fords and 87-91 Ferrari's. The 277881 was used by IH from 55-72.
It's too bad I already bought the MBS.
Chris
"The Fake Truck"
You can let the seal ride on the thrust bushing, that's how it's done on MGBs the inner and outer timkin with a bushing is how they do it.
The seal runs on the spacer
Seems like you guys have done the leg work for me
Moderated by  Dusty53
