| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Hi guys! To the left of the distributor- T1723577 The 1 may be an 'I' Thanks! Tom
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | number looks like a reman number, not factory
what year truck? what kind of engine? how about casting numbers?
Bill | | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | 1938 1 1/2 ton, May 1938 build date, looks like a 216, forgot to get the casting numbers. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | At first, I agreed with Bill; but, thanks to GM's Heritage Center's down-loadable library of Specifications Manuals, it looks like Tom's truck might well have a 1938 truck serial number in a correct format? ( Here is a PDF version of that ID page) T1723577 T = 1.5 ton truck from Flint Michigan assembly plant 1723577 = 1187822 (first truck serial number in 1938) = 535,775th truck out of the plant that year? Does this look right? 195447 is the first engine serial number in 1939. So, maybe Tom's code is good for 1938? Tom, can you find any date casting codes on the block/head? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | aah back at the beginning of the 216 - interesting a truck that old still has the original engine  Bill | | |
