0 members (),
116
0
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83909 10/08/2007 9:10 AM | Joined: Jul 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 70 | ok does anyone know what year if any rear axle will bolt up to a 37 gmc 1/2 pick-up i measured mine the other day and it is 60-7/16" from wheel mounting surface to wheel mounting surface.over all.Thanks Earl | | |
#83910 10/08/2007 4:18 PM | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Are you looking for stock type replacement torquetube? or anything that will fit? I used a 1973 thru 1979 Camero/Firebird axle in my '37 Chevy. Joe | | |
#83911 10/09/2007 3:24 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I used a 79/80 Malibu.....in my 37 | | |
#83912 10/09/2007 10:08 AM | Joined: Jul 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 70 | Hey Joe and A chipmunk thanks for the info. no i'm not using the torqure tube its got to go . i want to keep the body orginal in looks and a updated chaasis an drive line in it along with a bigger moter and a t-5 trans not sure if motor will be a newer bigger inline 6 or a 350 v-8? thanks again Earl | | |
