3 members (Guitplayer, Hush, Otto Skorzeny), 132 guests, and 1 robot.
Topics128,034
Posts1,055,540
Members48,425
#839045 03/27/2012 1:00 PM
hi just a quick question i know the mid 80s
s10 are favourable since they have a mechanic speedo but kan i get a newer(how new 1995/96? ) trans out of a s10 or s10 blazer?
the older ones is harder to get by here in norway..
wow this board is really helping me out
as im like it says a new guy!
cheers
chally #839046 03/27/2012 1:07 PM
The newer ones will have an electronic Speedometer. I'm not for sure when that started. I'm thinking around 92. I had a 95 Blazer with electric speedo.
Chris
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #839066 03/27/2012 2:56 PM
Riding in the Passing Lane
The 88 up have the electronic speedo. Around 95-96 they went to a different trans. that has the bell houseing built in. You cant use it. About 94-95 they used the World class model which is a little stouter then the non-WC. Get the number off the trans you are considering. Like 1352-xxx & look it up on a chart. It gives the gear ratios. Some ratios are not desireable for some applications. Like .086 overdrive wouldnt be much help with a low rear end.
1972 Chevy c10 Cheyenne Super
ok i think finding the right transmission here in norway wont be
as easy as i thought.... most s10 i have seen here has automatic
but i`ll keep my eye out there.... i have yet to buy a rear end so i guess i can match the rear to fit the ratio in the trans..
