| | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 51 | hi just a quick question i know the mid 80s s10 are favourable since they have a mechanic speedo but kan i get a newer(how new 1995/96? ) trans out of a s10 or s10 blazer? the older ones is harder to get by here in norway..
wow this board is really helping me out as im like it says a new guy!
cheers | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The newer ones will have an electronic Speedometer. I'm not for sure when that started. I'm thinking around 92. I had a 95 Blazer with electric speedo.
Chris
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 88 up have the electronic speedo. Around 95-96 they went to a different trans. that has the bell houseing built in. You cant use it. About 94-95 they used the World class model which is a little stouter then the non-WC. Get the number off the trans you are considering. Like 1352-xxx & look it up on a chart. It gives the gear ratios. Some ratios are not desireable for some applications. Like .086 overdrive wouldnt be much help with a low rear end. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 51 | ok i think finding the right transmission here in norway wont be as easy as i thought.... most s10 i have seen here has automatic but i`ll keep my eye out there.... i have yet to buy a rear end so i guess i can match the rear to fit the ratio in the trans..
