2 members (ndkid275, ronsway), 168 guests, and 3 robots.
Topics128,089
Posts1,056,139
Members48,435
I am having difficulty when shifting, after shifting into 3rd the engine slows like its being over burdened, yet it will speed back up and run fine when I shift into 4th it will do the same but if I'm not driving down hill it will stall, I've never hit 5th without going downhill also.
A military mecanic told me that in the transmission of the older m-35s there is rods that are adjustible and there just out of alinment causing the shifting problems,
Has anyone had this problem before? Does anyone know the correct term for these rods and know how to adjust them?
Thank you,
Akguy34
3B Offline
Hy akguy34, just wanted to wish you a Happy Birthday! I have no personal experience with that truck or transmission, but I'll see what I can find out. It sounds like something more than shifting difficulties if the engine will stall.
Yeah, happy Birthday, and that must be one heck of a truck!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Thank you guys,
When I would drive my s10 I had the same problem when I would skip gears (I was trying to get used to the shift pattern) the engine would act bogged down then it would regain enough power to work though it.
I am positive there is more to the problem with the engine sitting as long as it did but the way the problem progresses through the gears getting increasingly worse the high the gear seems to indicate an adjustment to me but I could be wrong.
well nevermind I just took my 42 out on our little road and it shifted flawlessly and the engine didn't stick wide open. I think it may have just needed run and to have the gears shifted some after sitting for so long.
ODSS Lawman
ODSS Lawman
Sometimes the best cure for these trucks is to just drive 'em!!!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
oh and I plan to.
Are you having shifting problems or is the engine bogging when you upshift. If the engine is bogging, you are not revving the engine fast enough or you are shifting in situations where you should stay in the gear you are in. You must remember you have you have a heavy vehicle with something like 100 HP.
