8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible),
181
Mod | | | Forums66 Topics128,086 Posts1,056,094 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 96 | I am having difficulty when shifting, after shifting into 3rd the engine slows like its being over burdened, yet it will speed back up and run fine when I shift into 4th it will do the same but if I'm not driving down hill it will stall, I've never hit 5th without going downhill also.
A military mecanic told me that in the transmission of the older m-35s there is rods that are adjustible and there just out of alinment causing the shifting problems,
Has anyone had this problem before? Does anyone know the correct term for these rods and know how to adjust them?
Thank you, Akguy34 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy akguy34, just wanted to wish you a Happy Birthday! I have no personal experience with that truck or transmission, but I'll see what I can find out. It sounds like something more than shifting difficulties if the engine will stall. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Yeah, happy Birthday, and that must be one heck of a truck! | | | | | Joined: Apr 2011 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 96 | Thank you guys,
When I would drive my s10 I had the same problem when I would skip gears (I was trying to get used to the shift pattern) the engine would act bogged down then it would regain enough power to work though it.
I am positive there is more to the problem with the engine sitting as long as it did but the way the problem progresses through the gears getting increasingly worse the high the gear seems to indicate an adjustment to me but I could be wrong.
| | | | | Joined: Apr 2011 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 96 | well nevermind I just took my 42 out on our little road and it shifted flawlessly and the engine didn't stick wide open. I think it may have just needed run and to have the gears shifted some after sitting for so long. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Sometimes the best cure for these trucks is to just drive 'em!!!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2011 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 96 | | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Are you having shifting problems or is the engine bogging when you upshift. If the engine is bogging, you are not revving the engine fast enough or you are shifting in situations where you should stay in the gear you are in. You must remember you have you have a heavy vehicle with something like 100 HP. | | |
