1 members (klhansen),
126
Mod | | | Forums66 Topics128,131 Posts1,056,726 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83857 10/06/2007 5:30 PM | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | The casting number on the block is either 3535911 or 3835911, I was wondering if someone could decode that number. Seems Like the 3835911 is the correct one.
Second, what are the sizes of the freeze out plugs on the side and on the front. The sides are in place, but the front is missing, and every size I got at the parts store is either to big or to small. If someone can help with the size and then point me in a direction where I can get them I would greatly appreciate it.
Thanks as always!
Mike My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man! 1953 Chevy 3100 Shortbed1965 C-30 Panel Truck 1963 C-20 Long/Fleet Pick-up California Black Plate
#83859 10/06/2007 11:10 PM | Joined: Jan 2004 Posts: 22 Apprentice | | Apprentice Joined: Jan 2004 Posts: 22 | Mike,
I have a 54 engine on the engine stand so I measured for you. Under the exhaust is 1 5/8 inch and the front and rear are 2 inch. That is also what was stamped in the plugs so my measuring was pretty good. Remember, mine is a 54 but it was easy to get to. Any other measurements you need before it goes back between the fenders (probably another year).
Later JJ and 4
Later JJ and 4 Keep the shiney side up
#83860 10/07/2007 3:46 AM | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | Thanks guys.
I will check the sizes from JJ.
I talked to Jim Carter, LMC and Chevy Duty with no luck, and checked Golden State and Bowtie Bits Catalog.
