| | | Forums66 Topics128,139 Posts1,056,459 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Why do my headlight bulbs sit too low in the housings of my '54 3100? There is a half inch gap at the top between the headlight retainer and the bezel. What did I do wrong? How do I correct the problem? I blasted and painted the housings and buckets. Replaced the adjuster nuts, bezel seals, clips for the seals, retaining rings, fender gaskets, and grommets. One of the headlights sat a little low previously, but it would move into place when I installed the bezel. Now, both headlights are too low for the bezels to massage into place. The springs were originally hooked in the lower hole of the buckets. I hooked them in the upper hole. Could that cause the problem? PIcs: > Gap between headlight retainer and rim> Bucket w/o bulb> Slot in housing for bezel> Top adjuster> Left adjuster> Spring> New seal inside> New seal outsideThanks for your help,
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Lonnie, I had the same problem with my left side headlight ring when I went to put it on. Seemed like the headlight was 1/4" to low. I kept messing with it and found part of the problem was them darn new clips I had bought to hold that ring around the inside of the bezel. The "top" clip would not let the ring go down far enough to slip over the headlight. I ended up with a different clip and using the adjuster screws I move them where the headlight "pulled up" as if aiming the headlight sort of high. the ring/bezel then slide over the headlight. ..oh, I had my spring hooked the bottom as original. Hope this helps you some. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I had the same problem Achipmunk describes. The new clip that snaps on the top didn't fit well. I ended up using my original trim pieces Try removing the top clip and do a test fit. Then modify Here is a pic of a later trim ring for comparison ...pic.. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks guys, including Denny in another thread.I'll play with them again today. I agree that the clip is probably my problem. Looks like there may be a little body filler at the top of the passenger headlight opening, so I gotta be gentle. Hope to get the radiator hoses on today, add water, and start 'er up for the first time in a month or so. Then I can aim the headlights tonight.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Success! The bezels are on and look good. The top mounting clip was not seating deeply enough into the slot in the headlight housing.
I did as Gus suggested and removed the top clip to see how the bezels sit on the retainer. Looked good, so I knew that the problem was with the housing or the top clip, not the bucket.
I did a couple of things that may have helped.
> I bent the top ears of the fender opening foward a little. ("Ears" are what I call the tabs on the fender that hold the speed nut doohickeys or a similar tab without a speed nut.) This moved the housing away from the top of the fender a little to give a bigger gap between the fender and the mounting slot for the bezel.
> I also tweaked the top wire mounting clip for the bezel.
Then I started mounting the bezel, firmly pushed the bezel down, and I could tell when the clip seated into the slot.
Luckily I aimed the headlights before I installed the bezels, 'cause I ain't takin' 'em off no mo. Followed the instructions for aiming in the Shop Manual. Used a couple of big pieces of paper with reference lines taped to my garage doors.
I had moved the springs to the bottom hole of the bucket and I left them there. I pulled one of the rivets out that holds them to the housing when I was moving from the top hole to the bottom one. I pop-riveted the spring to the housing - no problem, but I didn't want to risk pulling out the other one by fiddling with it.
Thanks for your help, for your pics, and for relaying your experiences to me.
