0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | My hood latch bolt continuously gets loose after drives. Ill make sure its tight before a ride and when i get back I'll check it again its loose. I've tried to get a bolt on the other end of the latch bolt, but none will fit because there isn't enough room on he latch bolt after going through the latch support. I asked my brother who has a 64 suburban and he has experienced the same thing.
I'm afraid one day it will get loose and fall off and my hood will fly up while driving. Any thoughts on how to approach correcting this? Thanks john
1964 K10 Fleetside Pickup Truck | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Loctite, staking the threads or a tack weld should do, Scott | | | | | Joined: Feb 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 52 | Are you talking about the large pointed pin that sticks up from the bracket that bolts to the core support. If so that pin is supposed to have a jamb nut that you tighten after you adjust it. Shoot me an email and I will send you a photo of what it is supposed to look like. I also have dozens of these nuts so I could send you one if you get the shiping.Sweet truck. I got to get some photos of my Blk 65 K10 on here.
65 K10 Longbox Fleetside Big Back Window Custom Cab 65 K10 Flatbed Old School Parts 60-66 (208)946-6173 [email protected]
| | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | Thanks Scott and 66Suburban for your replies.
66Suburban - I sent you a private email.
Thanks John
1964 K10 Fleetside Pickup Truck | | | | | Joined: Feb 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 52 |
