5 members (Hotrod Lincoln, Gdads51, Gray_Ghost, David Bush, Gib70), 118 guests, and 0 robots.
Topics128,051
Posts1,055,735
#838124 03/24/2012 4:04 AM
My hood latch bolt continuously gets loose after drives. Ill make sure its tight before a ride and when i get back I'll check it again its loose. I've tried to get a bolt on the other end of the latch bolt, but none will fit because there isn't enough room on he latch bolt after going through the latch support. I asked my brother who has a 64 suburban and he has experienced the same thing.
I'm afraid one day it will get loose and fall off and my hood will fly up while driving. Any thoughts on how to approach correcting this? Thanks john
1964 K10 Fleetside Pickup Truck
Loctite, staking the threads or a tack weld should do,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Are you talking about the large pointed pin that sticks up from the bracket that bolts to the core support. If so that pin is supposed to have a jamb nut that you tighten after you adjust it. Shoot me an email and I will send you a photo of what it is supposed to look like. I also have dozens of these nuts so I could send you one if you get the shiping.Sweet truck. I got to get some photos of my Blk 65 K10 on here.
65 K10 Longbox Fleetside Big Back Window Custom Cab
65 K10 Flatbed
Old School Parts 60-66
(208)946-6173
[email protected]
Thanks Scott and 66Suburban for your replies.
66Suburban - I sent you a private email.
Thanks John
Photos sent.
65 K10 Flatbed
(208)946-6173
[email protected]
