Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (50Chevy3100, carbking, NorCal52Suburban), 153 guests, and 9 robots.
Topics128,283
Posts1,058,519
Members48,490
My newly acquired 53 COE has a seat frame, in accordance with the shop manual, but not the seat and back cushions, which appear to be separate pieces. Can anybody tell me where I might be able to find replacements? Thanks in advance.
Post a Want Ad in the Swap Meet.
You might want to state GMC or Chevrolet (they might not be the same - they are not the same between GMC and Chevrolet in 1954/55).
The seat back, & cushions in a '47-'54 Chevy COE are the same as the pickups, & larger conventionals. Only the seat frame is slightly different.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
My '54 GMC COE has a rather odd seat that appears to use the same full-width back as the standard-cab trucks, but has two separate bucket-style cushions on each side of the engine hump.
1954 GMC De Luxe COE
Yes, That's the way GMC did, for '47-'54 COE's. You'll notice the '47-'54 GMC COE's have the two separate seat cushions because the shifter comes straight up through the floor from the transmission. The '47-'54 Chevy COE's use the full width bottom with a special linkage assembly, that comes up through the floor then turns towards the front, & out from under the seat (seat frame made different at this point) to a special short shifter attached to the center engine cover panel. This engine cover panel, is the only hump, that is in any Chevy, or GMC COE, & it's out in front of the tranny. The area over the transmission, on both Chevy, & GMC COE's is flat, & below, the driver, & passenger.
Spanky Hardy
1950 GMC 250 1-Ton
Moderated by  ndkid275, Phak1
