0 members (),
133
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | My newly acquired 53 COE has a seat frame, in accordance with the shop manual, but not the seat and back cushions, which appear to be separate pieces. Can anybody tell me where I might be able to find replacements? Thanks in advance. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Post a Want Ad in the Swap Meet.
You might want to state GMC or Chevrolet (they might not be the same - they are not the same between GMC and Chevrolet in 1954/55).
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The seat back, & cushions in a '47-'54 Chevy COE are the same as the pickups, & larger conventionals. Only the seat frame is slightly different. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | My '54 GMC COE has a rather odd seat that appears to use the same full-width back as the standard-cab trucks, but has two separate bucket-style cushions on each side of the engine hump.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Yes, That's the way GMC did, for '47-'54 COE's. You'll notice the '47-'54 GMC COE's have the two separate seat cushions because the shifter comes straight up through the floor from the transmission. The '47-'54 Chevy COE's use the full width bottom with a special linkage assembly, that comes up through the floor then turns towards the front, & out from under the seat (seat frame made different at this point) to a special short shifter attached to the center engine cover panel. This engine cover panel, is the only hump, that is in any Chevy, or GMC COE, & it's out in front of the tranny. The area over the transmission, on both Chevy, & GMC COE's is flat, & below, the driver, & passenger. | | |
