7 members (Otto Skorzeny, dt235sd, FAST55, FishinToms53, 3B, Rusty Heaps, 1 invisible),
100
Mod | | | Forums66 Topics128,115 Posts1,056,632 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 21 New Guy | | New Guy Joined: Mar 2012 Posts: 21 | I have seen that several sites now seem to offer new style roller bearings instead of the old style ball bearings. They cost more, is there any real practical benefit? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not unless you want to switch to disc brakes, you may even find the bearings on yours are the ones it came from the factory with
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The ball brgs are fine as long as you grease them properly. If you need to replace most or all the brgs then you could go to the rollers. Like Red says if you switch to discs you should change to thr rollers. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2012 Posts: 21 New Guy | | New Guy Joined: Mar 2012 Posts: 21 | Well I know that the bearings that are on it are not original, but they are the original style. I did a really really bone headed thing the other day and kinda screwed up the outer bearings. The bearings themselves and the races are still intact but I really should replace them. Was curious if I should go with the new style. Looks like there isn't much point, the old style has worked this long, why change it if it works right? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the ball bearings work fine and are readily available at parts stores
Bill | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | A long time ago, someone in the bearing industry said on this forum that ball bearings, because of less contact area, can run cooler naturally that roller bearings and that they were perfectly fine in our trucks.
I suspect that the industry went to rollers because it's cheaper to make them. It's got to be easier and cheaper to make a uniform rod (and chop it up) than to make perfect metal balls one at a time. But that's just my guess. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I don't know if they've switched, but at least until recently BMW was still using ball bearings. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | My model T has taper roller bearings.... Hahahaha. I think they're all good, with cleaning and grease. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | In my opinion, I believe the tapered roller bearings are essentially a dumbed down version. They are very simple to adjust and even when not adjusted properly (within reason) they still seem to work without destroying the bearing and races.
My experience with ball bearings is that they have a specific torque value rather than 'spin the wheel and tighten' with typical tapered roller bearings. Ball bearings not adjusted properly seem a bit more capable of self destructing and fairly quickly at that.
Jeff | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something to consider, virtually ALL modern vehicles use ball bearings at least in the front, with FWD cars using the on all 4 wheels.
Bill Burmeister | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | One advantage to roller bearings is higher load bearing ability. They spread the weight out over a larger area, instead of just one spot. Probably the most significant other advantages are that they have higher lateral (side load) ability and higher shock load ability. These things are important every time you hit a bump, turn your wheel, or use your brakes. The industry all but abandoned the ball type wheel bearing. Why? Because they are better. Like Longbox (Bill) stated, ball bearings are still being used in cars, but that is in sealed unit bearing applications. My money is on the roller bearings.
Chris | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | "They cost more, is there any real practical benefit?"
As someone who has gone through a couple sets of roller bearings on a truck, my opinions are mixed. The roller bearings are cheaper to obtain than the standard ball bearings. The quality of both ball bearings and roller bearings comes into question. With all bearings being made in China, I don't believe either will last.
When it comes to bearings look for the older American made Ball bearings, or the discontinued Japanese MBS roller bearings. I believe those to be superior to the chinese ones available today. It will likely cost more... about 2x more to get the better bearings. 2x more is still cheaper than being stuck on the side of the road 100s of miles from home with fried bearings on multiple occasions. Most parts houses no longer carry our obsolete bearings.
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | With all bearings being made in China In my personal experience, this is far from true. Most parts houses no longer carry our obsolete bearings. I've had good luck finding really obsolete stuff through NAPA, CarQuest and Federated. Places like O'Reilly, AutoZone and Pep Boys are pretty good for newer stuff, but you have to go to the pros for the more oddball parts. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Original-style roller bearings are available at NAPA (in stock, where I live - I bought some in the past year).
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | It seems as though Timken, Federal Mogul, and SKF all have the ball bearing type availible. They're probably made overseas, but they all have good quality standards. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Originally Posted By: bigbadswingdaddy
Sam, I know you are not trying to be argumenitive. However, After going through a terrible ordeal of losing a tapered roller bearing on a road trip, I HAVE TO DISAGREE WITH YOU!
The NAPA I broke down closest to had one BCA outer ball bearing in stock, and I was able to pick it up, install it and get on my way. The bearing I got was the last one they would ever carry. I kind of lucked out on that. By the way do you know what happens when you use a roller bearing inner, and a ball bearing outer on an old truck? I do! You end up having a catastopic falure in which the spindle, hub, and bearings all get fried, forcing you to source a new front axle.
My [questioned] point from above... get the best bearings you can. There is nothing aybody can or will ever say that will ever convince me Chinese made bearings are equal in quality to American made bearings. They can't be, the metalurgy is all wrong.
When it comes to the front bearings for our 1/2 ton trucks, the roller bearings are one off bearings that are made in China. The first batch of these bearings were made in Japan. The Japanese bearings are far superior to the Chinese bearings. You can find the Chinese roller bearings on sale for $69.95 on occasion, although the kit usually costs around $130. You can also source the MBS japanese roller bearings from a local bearing house for upwards of $250 for the set. I understand that more expensive doesn't necessarily mean better quality. I have not had any problems with the MBs bearings. The chinese roller bearings wore prematurely and left me stuck on the side of the road on numerous occasions. Again I wore out 2 complete sets of the Chinese roller bearings in less than 30,000 miles of driving.
I'm a firm believer in the old addage... Good stuff ain't cheap, and Cheap stuff ain't good! | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I don't know what your situation was, but I've never heard of anyone mixing a ball bearing and roller type on the same spindle. I would think it would cause severe alignment issues, maybe even create some harmonics. Secondly, I can't speak for the "Chinese" made bearings, but the MBS ones I have for my 3/4 ton are beefcakes compared to the BCA ball bearings I took off. They seem to be an excellent quality product. I guess I was lucky, being able to get them still. I took some pictures of them side by side for comparison. Night and day difference. www.photobucket.com/whitedog76picsChris | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | No issues with the MBS bearings. The issues were with the no name Chinese roller bearings supplied by an after market brake company.
When you are 100 plus miles away from home with a broken truck, you will buy the bearings that are available. In my case, only the outer bearing was available, and I WAS able to continue on my trip and get home with the mix matched bearings. Catastropic falure happened about 3500 miles after the mismatch. The roller bearing that went bad on the trip, was the third bearing to go bad on me. I had previously replaced the hub when the last one failed. When the mixed roller/ball bearing hub failed, it destroyed the hub, spindle, and bearings. I had to replace the axle, or at least the spindle, and all the chinese roller bearings with the higher quality Japanese MBS bearings.
Again the caution is in using cheap inferior bearings, which in my opinion is any bearing made in CHINA.
I may be the only person who has ever had problems with the Chinese roller bearings... Then again... maybe just another unsatisfied customer. | | | | | Joined: Sep 2011 Posts: 1,458 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,458 | Mixing ball & roller type wheel bearings is a bad idea on any rig. If you check a service manual ball bearing require a preload while tapered roller bearings usualy have a slight end play.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Saying "don't use no-name bearings made in China" is far from saying "all bearings are now made in China." US-made bearings may be rare these days, but quite a few are still made in Europe to very good quality standards. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I may be the only person who has ever had problems with the Chinese roller bearings... Then again... maybe just another unsatisfied customer. Your not the only one. After contacting a vendor to order new ball bearing types, they assured me they were American made. After recieving them they had 'CHINA' stamped on the side. In my hand the bearings were sloppy in the race. They were complete pieces of crap. They went back in a heartbeat and I ordered from a reputable bearing supplier and got Japanese made MBS in return. Several years later, not a single problem. Jeff | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | "Saying "don't use no-name bearings made in China" is far from saying "all bearings are now made in China." US-made bearings may be rare these days, but quite a few are still made in Europe to very good quality standards."
Sam, since you seem to be an expert, What companies are still making these 60 year old obsolete ball bearings, and where are they manufactured? I would like to know so I can write the company a good old fashioned Attaboy!
