1 members (NJC), 62 guests, and 1 robot.
Topics128,089
Posts1,056,004
Members48,430
#836152 03/17/2012 11:51 PM
Hey there,
does anyone have a working set of door locks with key(s) for a '65 C20? My locks work, but I only got one key for the ignition when I bought the truck, none for the doors.
Greetings from Germany
Joern
'65 C-20 Fleetside 283 4-speed-MT
I got a complete set of locks n keys from LMC Truck. I imagine they will ship to Germany.
http://www.lmctruck.com/icatalog/cbe/full.aspx?page=46
Hope this helps.
The glass is twice as big as it needs to be.
You can also remove the lock cylinder out of the door handle and take it to a locksmith and they can make you a key.
65 K10 Longbox Fleetside Big Back Window Custom Cab
65 K10 Flatbed
Old School Parts 60-66
(208)946-6173
[email protected]
Wow, that's possible? I didn't know this, but I will try that because I want to keep as much from the original stuff as I can.
LMC would be an option, but maybe someone has an original set, not repro.
Thank you
Hey Joern. I have a complete set of right & left outside door handles with locks & matching keys, if you are sitll looking.
The ignition and door locks use the same key. If yours do not match (not uncommon if either have been changed), a locksmith can make them match. I did that on mine, which had mismatched ignition, glove box, and door locks. Wasn't too much trouble, and the cost was minimal.
Bill Burmeister
If the ignition, glove box & doors came from the factory with keyed tumblers, then they had one key, unlike the cars of the same era, which had an ignition key and a different truck & door key.
Thanks, I will try this and get all locks off the truck on wednesday.
Joern
By the way, another question:
When I pull the headlight switch to first position, all parking lights come on. When I pull it to second, the headlights come on and the front parking lights are turned off. Is that correct? Or should the parking lights stay on regardless off the headlights?
Thank you!
Joern
Factory correct: The parking lights in the front go out when the headlights come on. You can add a jumper so they stay on when the headlights are on.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I second that...
Yes john is correct. I never understood why they did that. It seems strange for them to go out.
65 K10 Flatbed
(208)946-6173
[email protected]
Back then they were "parking" lights, and only on when you were parked or idling thru the drive-in.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I didn't know this and was wondering if it was only on my truck or factory correct. Because on my other truck they are constantly on which is necessary to get it street legal.
This is how we do the jumper to keep the park lamps on in middle-position & out-position on headlight switch:
Park Lamp Jumper
The jumper connects the blue wire and purple at the headlight switch harness.
Hey Joern. I sent you a PM regarding the key-alike door handles, ignition switch & glove box lock, so please let me know if I can help.
Thanks for the image, i will do my harness the same.
