2 members (homer52, Tronman),
239
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 32 New Guy | | New Guy Joined: Oct 2011 Posts: 32 | Hey there,
does anyone have a working set of door locks with key(s) for a '65 C20? My locks work, but I only got one key for the ignition when I bought the truck, none for the doors.
Greetings from Germany Joern
| | | | | Joined: Feb 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 38 | I got a complete set of locks n keys from LMC Truck. I imagine they will ship to Germany. http://www.lmctruck.com/icatalog/cbe/full.aspx?page=46Hope this helps.
The glass is twice as big as it needs to be.
| | | | | Joined: Feb 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 52 | You can also remove the lock cylinder out of the door handle and take it to a locksmith and they can make you a key.
65 K10 Longbox Fleetside Big Back Window Custom Cab 65 K10 Flatbed Old School Parts 60-66 (208)946-6173 [email protected]
| | | | | Joined: Oct 2011 Posts: 32 New Guy | | New Guy Joined: Oct 2011 Posts: 32 | Wow, that's possible? I didn't know this, but I will try that because I want to keep as much from the original stuff as I can.
LMC would be an option, but maybe someone has an original set, not repro.
Thank you
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Hey Joern. I have a complete set of right & left outside door handles with locks & matching keys, if you are sitll looking.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The ignition and door locks use the same key. If yours do not match (not uncommon if either have been changed), a locksmith can make them match. I did that on mine, which had mismatched ignition, glove box, and door locks. Wasn't too much trouble, and the cost was minimal.
Bill Burmeister | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | If the ignition, glove box & doors came from the factory with keyed tumblers, then they had one key, unlike the cars of the same era, which had an ignition key and a different truck & door key.
| | | | | Joined: Oct 2011 Posts: 32 New Guy | | New Guy Joined: Oct 2011 Posts: 32 | Thanks, I will try this and get all locks off the truck on wednesday.
Joern | | | | | Joined: Oct 2011 Posts: 32 New Guy | | New Guy Joined: Oct 2011 Posts: 32 | By the way, another question:
When I pull the headlight switch to first position, all parking lights come on. When I pull it to second, the headlights come on and the front parking lights are turned off. Is that correct? Or should the parking lights stay on regardless off the headlights?
Thank you!
Joern | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Factory correct: The parking lights in the front go out when the headlights come on. You can add a jumper so they stay on when the headlights are on.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | | | | | | Joined: Feb 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 52 | Yes john is correct. I never understood why they did that. It seems strange for them to go out.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Back then they were "parking" lights, and only on when you were parked or idling thru the drive-in. | | | | | Joined: Oct 2011 Posts: 32 New Guy | | New Guy Joined: Oct 2011 Posts: 32 | I didn't know this and was wondering if it was only on my truck or factory correct. Because on my other truck they are constantly on which is necessary to get it street legal. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | This is how we do the jumper to keep the park lamps on in middle-position & out-position on headlight switch: Park Lamp JumperThe jumper connects the blue wire and purple at the headlight switch harness. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Hey Joern. I sent you a PM regarding the key-alike door handles, ignition switch & glove box lock, so please let me know if I can help.
| | | | | Joined: Oct 2011 Posts: 32 New Guy | | New Guy Joined: Oct 2011 Posts: 32 | Thanks for the image, i will do my harness the same. | | |
