1 members (55shaker),
42
Mod | | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#8367 07/31/2004 10:58 PM | Joined: Jan 2004 Posts: 30 Junior Member | | Junior Member Joined: Jan 2004 Posts: 30 | i cleaned out the varnished fuel from gas lines, tank and fuel filter on my 46 1 1/2 ton and now i get no fuel from the tank. all the lines are dry and i can blow air into tank. do i need to prime the gas lines? the pump worked before i cleaned everything out. i can find nothing in a search. any ideas | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Take off the fuel pump and work it by hand...does it sound like it is working? Your local Napa should have a fuel pump for cheap. That might fix your problem.
starting simple...is the valve under the tank open?
Does gas run from the tank to the pump when gas is installed in the tank? If yes...then is pump.... | | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | I replaced my pump a year or so ago for less then $20.00.
How long did the pump sit while you cleaned the tank and lines. If it was a while the diaphram may have dried out and cracked.
Disconect the output to the carb and place you finger over the fitting. Keep clear of all moving parts and have someone crank the engine. You should be able to tell if you are pushing any air. Or you could just remove the fuel line at the carb and put it(the fuel line) into a clear bottle and crank.
Do you have the fuel filter in the right direction? Is the shut off valve open? Do you have pleanty of gas in the tank?
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jan 2004 Posts: 30 Junior Member | | Junior Member Joined: Jan 2004 Posts: 30 | there is a couple of gallons of gas in the tank. the pump sat a week or so without gas in it but the glass bowl was on. when the gas line is unhooked there is no gas coming out. i blew air into line and heard bubbling in the gas tank. it seems like the gas line dips low and comes up higher to get to fuel tank. do i need more fuel in tank? | | |
