3 members (Ponchogl, ShopRag, 52hornsby), 81 guests, and 2 robots.
Topics128,035
Posts1,055,564
#836121 03/17/2012 9:42 PM
I have a 1948 3/4 ton. The suspension is 100% stock. Any advise on updating the old knee shocks to more modern shocks? I have seen shock mounts, but they are for the 1/2 ton.
Can some please tell me this is a cheap and easy fix?
Who owns this car with the peace sign, mag wheels, and 4 on the floor?
Dude- 1948 Chevrolet Thriftmaser 3600
https://i.imgur.com/NN2ehrsl.jpg
This is what I did. I have a 46 1/2 ton that I converted to tube shocks from knee action. I got some lower front tube type shock mounts off an Advance design series (47-50something.) that was in a junk yard. The mount was in a straight up and down orientation, I've seen some that have an angle towards the front of the truck I guess the choice is up to you. Anyway, got the lower shock mounts mounted to the leaf springs and measured the travel. Then I got on the monroe web site and found a shock with that travel with posts mounts on both ends ( choices are post or fork mount etc). These turned out to be off a 53 vette.
I made some upper mounts off of flat steel, bent them into a 90, welded some webbing for added strengh, attached to the frame and been running that way for about 5000 miles.
This is just a suggestion that worked for me I can't say it will work for you.
elmer46 #836657 03/19/2012 6:26 PM
The 47-55.1 AD trucks had basically the same front suspension. I wouldn't hesitate putting the 1/2 ton shock and mounts on a 3/4 ton. I looked in my LMC catalog and they had the same bracket and shock listed for the 1/2 and 3/4 ton for 50-55. Not to mention they used the same leaf spring setup from 47-55.1. Seems to me, it's a natural fit.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #836712 03/19/2012 11:50 PM
Thanks!.....(runs off to the LMC webpage....)
After much research, I cannot figure a way to get tube shocks on the rear of the 3600 without much fabrication. The front is indeed the same as a 1/2 ton. The rear however, is much different. The leaf springs are mounted out board of the frame. In a 1/2 ton, the leaf springs are directly under the frame.
I am open to suggestions.
jjrockbush #855038 05/29/2012 10:51 PM
chevy s-10 has the lower shock mounts, that will work on the back and what I did was bolted a piece of angle iron between the frame rails and made my own upper shock mounts u can see in my pictures
http://s629.photobucket.com/albums/uu14/kurtdh519/
all i did with the bottoms mounts was drill the u bolt holes closer so I could use my original springs
