2 members (baldeagle, Tony292),
43
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | I have a 48 chev canadian truck with a replaced motor I would like to find out what it is. the casting # is 3788387 thanks Doug | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | I guess nobody has any idea,s ? should be about 57-62 235,but don,t know for sure. I need a carb kit and carb has no #s thank,s doug | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Can you post the s/n just behind the distributor Should look like this ...pic... Someone will be able to identify your 235 from your s/n You will not be able to identify your carb from that number. If you can post a pic of your carb it might help | | | | | Joined: Mar 2010 Posts: 37 New Guy | | New Guy Joined: Mar 2010 Posts: 37 | thank,s Dads50. the # behind the dizzy has no letter,e in it. The # is283185. bear in mind this is a canadian truck. Thanx Doug | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Hopefully someone will be along to run the numbers for you, it might not be a 235
Any pics? | | |
