Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (Jon G, 68ironhead, Stovebolt48, baldeagle, GMCJammer51, dt235sd, panic, JW51, 1 invisible), 51 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#836174 03/18/2012 12:42 AM
Z
z48
Offline
Z Offline
I have a 48 chev canadian truck with a replaced motor I would like to find out what it is. the casting # is 3788387 thanks Doug
z48 #836340 03/18/2012 4:27 PM
Z
z48
Offline
Z Offline
I guess nobody has any idea,s ? should be about 57-62 235,but don,t know for sure. I need a carb kit and carb has no #s thank,s doug
z48 #836342 03/18/2012 4:39 PM
Can you post the s/n just behind the distributor
Should look like this ...pic...
Someone will be able to identify your 235 from your s/n
You will not be able to identify your carb from that number. If you can post a pic of your carb it might help
DADS50 #836373 03/18/2012 6:49 PM
Z
z48
Offline
Z Offline
thank,s Dads50. the # behind the dizzy has no letter,e in it. The # is283185. bear in mind this is a canadian truck. Thanx Doug
z48 #836379 03/18/2012 7:28 PM
Hopefully someone will be along to run the numbers for you, it might not be a 235
Any pics?
