4 members (Hotrod Lincoln, Bill Hanlon, Wheelie, sron48), 103 guests, and 5 robots.
Topics128,184
Posts1,057,195
Members48,465
I just reverted to a 1957 standard axle that SWEET helped me rebuild. My son and I put it under the truck (after fighting out the old) and it mates up pretty good.
However, I realized I don't know what the proper length that the driveshaft can be out the back of the transmission is. Meaning, The shaft can move in and out some, but I don't know by how much.
My worry is that someone, when they installed the posi rear end (5-bolt) may have shortened or replaced the driveshaft with one of a different length.
With the driveshaft fully inserted into the trans, I have a gap between the differential and U joint of about 1.5 inches. The driveshaft can travel out from the trans that far and SEEMS okay, but is this normal? My driveshaft is now about 1.5 inches from where it bottoms against the trans end.
Here's a shot of the gap with the driveshaft fully inserted into the trans.
http://i1195.photobucket.com/albums/aa397/fourbrads/57%20chevy/DSC03161.jpg
Any help/advice is appreciated.
Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
the slip yoke needs to have enough movement to accept the movement of the drive shaft fore and aft as the rear end moves up and down, it should not be fully in, so yes, 1.5" is probably about right
Thanks Bill,
I checked and can't see any of the yoke splines outside of the tailshaft, so I think I'll be okay.
I appreciate your reply.
Best,
Jim
235, 3-speed w/OD
