3 members (TUTS 59, 1955 1 Series, dt235sd), 97 guests, and 2 robots.
Topics128,141
Posts1,056,488
Members48,441
#835506 03/15/2012 5:13 PM
My build is a '49 5-window 3100 on a S10 frame. I know!,I've read all the pros and cons about this swap, but I am retired and it keeps me busy. I need some idea as to installing a S10 blazer gas tank at the rear of the frame. This is my first truck build and this site is awsome. Thanks, Fubar 49
Welcome fubar. The fuel pump is inside the tank so if you Google "S10 blazer fuel pump replacement" you should find a few videos that will show you the mounting method/locations. If you need some specific dimensions mine is in the parking lot and I can check for you.
You Tube
