7 members (Jon G, Youngin' Tut 59, Lightholder's Dad, Ponchogl, 3 invisible), 121 guests, and 3 robots.
Topics128,132
Posts1,056,384
Members48,441
#834427 03/12/2012 3:57 AM
So I'm still learning everything about my 52 3100. I have a 235 in it from 1960 and I have got to change the oil. What type of oil do you guys recomend. thanks a lot
I'd venture to say that anything you buy today, is better than anything that was available back in yon olden days.
Lots of people run everything from 10-30, right up to straight 40.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
20, 10W30, no thicker until it's hot outside.
Appreciate the responces guys I was hoping it would be that simple
just remember the oil made today is not the greatest for the flat tappet engines. there has been a reduction on a ingredient per the government. I have a 65 mustang and when i rebuilt the engine i did a lot of research on this and ended up using a additive.
Basham is right, new oils have less zinc and other additives needed for a proper break in. But your engine just needs a oil change, not break-in. Any name brand oil will work fine, stick with the shop manual oil weight to temperature scale and you will be fine.
Joe
good oil to use is shell raetta oil 15x40
