1 members (Rich'sToys),
90
Mod | | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 17 New Guy | | New Guy Joined: Jan 2012 Posts: 17 | So I'm still learning everything about my 52 3100. I have a 235 in it from 1960 and I have got to change the oil. What type of oil do you guys recomend. thanks a lot | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I'd venture to say that anything you buy today, is better than anything that was available back in yon olden days.
Lots of people run everything from 10-30, right up to straight 40.
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | 20, 10W30, no thicker until it's hot outside. | | | | | Joined: Jan 2012 Posts: 17 New Guy | | New Guy Joined: Jan 2012 Posts: 17 | Appreciate the responces guys I was hoping it would be that simple | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | just remember the oil made today is not the greatest for the flat tappet engines. there has been a reduction on a ingredient per the government. I have a 65 mustang and when i rebuilt the engine i did a lot of research on this and ended up using a additive. | | | | | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | Basham is right, new oils have less zinc and other additives needed for a proper break in. But your engine just needs a oil change, not break-in. Any name brand oil will work fine, stick with the shop manual oil weight to temperature scale and you will be fine.
Joe | | | | | Joined: Jun 2010 Posts: 298 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 298 | good oil to use is shell raetta oil 15x40 | | |
