2 members (klhansen, TUTS 59),
64
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Hey Everyone, I am about to set my engine and I am looking for some advice. I had posted a thread in the engine shop but the only advice I received was from 3B. It makes sense and I'm going to try it but I want to make sure that I have other checks and balances. I am open to just taking it to the local rod shop and have them do it for me. Any suggestions? Bread Pic 1 Pic 2 pic 3 Pic 4 | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | That looked like good advice from 3B IMO.
I think it would also be worth have your steering rack in place when you decide on your motor placement, just to make sure you don't end up having to do something difficult/impossible with the steering column routing afterwards. | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | I would tack weld everything till I had 90% of all parts installed. Its more work to pull it back apart, but a lot less work then cutting whole welds out when you find it wrong.
Joe | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Gents, Thanks for the advice and I'm going to run with it.
Bread | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | One more word of advice. . .Don't get your driveshaft made until you are 100% sure of the engine placement. I have moved my engine twice already. Final resting place now, but it cost me $$$ because I was "SURE" about the placement before!
Just me on my soapbox. . .
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
