1 members (1 invisible),
78
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I ordered a wood block kit for my 49 1-ton chevy with 9' bed. Most of the blocks have a hole in the center, But two of them have the hole offset some from center, Can anyone tell me where these go? Thank you, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I have no experience with a 1 ton 9' bed so comparison with a 1/2 ton may not be accurate. However, on my 1952 1/2 ton is is pretty easy to see which mounting hole in the frame is offset. On the 1/2 ton it is for the cross member just in front of the rise of the frame to clear the rear end.
Chuck | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I found the info. from mar-k. the offset blocks go under the back brace before the rear cross sill. there offset to miss a set of rivits in the frame.
