5 members (rick46ia, elhippie64, Peggy M, JW51, 1955firstseries), 66 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#834922 03/13/2012 5:20 PM
I ordered a wood block kit for my 49 1-ton chevy with 9' bed. Most of the blocks have a hole in the center, But two of them have the hole offset some from center, Can anyone tell me where these go? Thank you, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
491ton #834941 03/13/2012 6:18 PM
I have no experience with a 1 ton 9' bed so comparison with a 1/2 ton may not be accurate. However, on my 1952 1/2 ton is is pretty easy to see which mounting hole in the frame is offset. On the 1/2 ton it is for the cross member just in front of the rise of the frame to clear the rear end.
Chuck
Hookalatch #848626 05/03/2012 3:51 PM
I found the info. from mar-k. the offset blocks go under the back brace before the rear cross sill. there offset to miss a set of rivits in the frame.
