2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Does anyone have a link to a quite clear photo of the firewall (from the engine side) showing the correct routing, and which holes to use, for the Oil, temp, and speedometer cables? I'm at the point where I can change what I have done, but that will get more difficult as I proceed.
PS: I went thru the photos on Jim Carter, and no luck with that. Gary Fossen
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | This is the info for the 1939 Truck Tech Rep. for the Vintage Chevy Club of America: Charles Hoback 509 Florence Bloomington, IL 61701 309-829-6386 [email protected]Hopefully he can help you.
1939 Chevrolet Stake Truck
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My '38 coupe has the choke/throttle/water temp/oil pressure lines through the oblong grommet in the center of the firewall just above the valve cover, in that order from passenger side to driver's side. The speedometer cable routes through the large hole to the driver's side of the mast jacket. <CLICK>
| | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Rick and Tiny,
The line up for the center grommet sounds better than the way I have them. Also, I was able to find a photo of the interior, and the choke and throttle are in that order on the dash, so it makes sense. I will re-align mine, and get them where they belong.
Gary | | |
