1 members (1 invisible), 78 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#833680 03/09/2012 3:59 PM
Does anyone have a link to a quite clear photo of the firewall (from the engine side) showing the correct routing, and which holes to use, for the Oil, temp, and speedometer cables? I'm at the point where I can change what I have done, but that will get more difficult as I proceed.
PS: I went thru the photos on Jim Carter, and no luck with that.
Gary Fossen
This is the info for the 1939 Truck Tech Rep. for the Vintage Chevy Club of America:
Charles Hoback
509 Florence
Bloomington, IL 61701
309-829-6386
[email protected]
Hopefully he can help you.
1939 Chevrolet Stake Truck
Ex Hall Monitor
Ex Hall Monitor
My '38 coupe has the choke/throttle/water temp/oil pressure lines through the oblong grommet in the center of the firewall just above the valve cover, in that order from passenger side to driver's side. The speedometer cable routes through the large hole to the driver's side of the mast jacket.
<CLICK>
Tiny #833803 03/10/2012 12:55 AM
Rick and Tiny,
The line up for the center grommet sounds better than the way I have them. Also, I was able to find a photo of the interior, and the choke and throttle are in that order on the dash, so it makes sense. I will re-align mine, and get them where they belong.
Gary
