3 members (Otto Skorzeny, Shaffer's1950, 1 invisible), 164 guests, and 5 robots.
Topics128,088
Posts1,056,122
Members48,435
#832782 03/06/2012 7:17 PM
I
I Offline
When I yank this 350, and put this 454 in...it should hook right up to the same tranny I was told. Is this right ? Thanx smile
need more info. I believe the small block bell housing will not work on the big block.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
3B Offline
Hy IsolationRide, yes it should bolt up. All Chevrolet V8s from 1955 up to the LS series (1997?) have the same bellhousing bolt pattern, also the inline sixes from 1963 up, I,m not sure about the Chevy V6s as I have no experience with them. Hope that helps
I
I Offline
so probably keep the 400 turbo tranny for 454 then right ?
IsolationRide #832826 03/06/2012 10:26 PM
the TH400 is a commonly used trans with a 454, although you might look for a 4L80, which is as beefy as the 400 but has OD
IsolationRide #832852 03/06/2012 11:40 PM
Just make sure you have the correct flywheel for the 454. The 350 flywheel will not work on the 454.
