| | | Forums66 Topics128,185 Posts1,057,284 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 29 New Guy | | New Guy Joined: Aug 2000 Posts: 29 | I am starting a rolling restoration of a '37 1/2 ton. The transmission has stamped on top "C 22 7". Can someone tell me something about this tranny? Are parts available for a rebuild? How complicated is a rebuild for an amateur?
Thanks | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I can tell you that the parts, mainly all of the gears and some other parts, are the same from 37 to 54. In other words, the guts from a 54 transmission will fint in a 37 transmission case. I can't tell you about the availability of parts, but there should be some out there considering the range of years these part were used.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1937-39 have straight cut first gear, syncro drum and main shaft. You can use 1940-54 gears and shafts but the spline for the u' joint is slightly different, but there are options there. 1937-39 parts are available if needed. PM me if you have trouble finding parts.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | They are a simple trany, but this is a good time to get a shop manual.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | I've recently worked on my 37 3-speed, and would agree with the suggestion to get the shop manual. I also found the master parts book to be helpful in determining what fits between what years.
I found replacement bearings on Ebay as well as replacement gears.
Also, a 37 car transmission uses the same basic gears, except that the truck has a longer output shaft (transmission is longer to fit in the same space as a 4-speed.)
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | |
