0 members (),
88
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I am cleaning up a recently rebuilt 235 (58 casting number) and I have a few gasket questions.
Is there an o-ring or gasket under the distributor? Or do you just use a bit of silicone?
I can't find the thermostat HOUSING gasket where it attaches to the head. It's a retangular gasket. I might have to make one? I know they are included in a full set or a head gasket set. Any ideas?
One last question for this post. I have no problems getting top dead center and alighning the dizzy/rotor, however where should number one position be located as i am looking at the engine from the front? Right now it is at toward the number 2 cylinder. I hope I am asking this clear enough?
Thank you.
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | There is a groove for an O ring on the distributor housing, but since it's in constant motion from the action of the vacuum advance, it would probably wear out pretty quickly. Most of the distributors I've seen don't have the ring there, so I'm going to assume most of them wear and disentigrate.
It doesn't really matter which distributor cap tower is used for the #1 plug wire, as long as the firing order is correct as the other wires are inserted. The correct firing order is 1-5-3-6-2-4 in a clockwise direction. My Motor Magazine service manual shows the #1 position at the cap tower just clockwise from the terminal where the wire to the points attaches. Jerry
| | | | | Joined: Sep 2011 Posts: 116 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 116 | On my 248 (and any other engine I've worked on) nothing under the distributor, the gasket behind the thermo housing was nothing special, you should be able to make one easily, #1 on my dist. is at about 1:30 as you're looking at the dist. from that side of the engine, so if I'm understanding you, I think you're close. Hope this helps 1955 Second Series GMC"Done - A 50 Year Journey"Follow in the DITY-- No one said it was going to be easy
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Chevrolet never used an O ring on the shaft. A lot of rebuilt distributors come with one, but if installed that way will lock the twisting action needed for the vacuum advance.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Thanks folks. Appreciate the feedback. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I believe #1 should be at about the 5-6 o'clock position. I could not find a better picture but in this cutaway picture you can see #5 wire. #1 is just before #5 in the firing order. 153624. SHOP MANUALAlthough any position will work if put in time. HERE IS ANOTHER PIC. Fig #6
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 26 New Guy | | New Guy Joined: Mar 2010 Posts: 26 | the thermostat gasket is in the truck shop cat. truckandcarshop.com | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | The thermostat gasket you can get at any FLAPS.
Pete | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Thanks again folks. Just to clearify, I'm looking for the thermostat housing gasket, where it's bolts to the head. I think I can just make one.
Also, I think you are right on the rotor position for number one. Easy to turn and fix. I also have my coil up instead of down. I wonder what the reasoning of facing the top downward? Interesting.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I always like the coil mounted with the wires up. I have seen to many coil wires fall out the other way.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | You can get the housing gasket at any FLAPS.
Pete | | |
