1 members (Hotrod Lincoln), 116 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#832073 03/04/2012 3:05 PM
I am cleaning up a recently rebuilt 235 (58 casting number) and I have a few gasket questions.
Is there an o-ring or gasket under the distributor? Or do you just use a bit of silicone?
I can't find the thermostat HOUSING gasket where it attaches to the head. It's a retangular gasket. I might have to make one? I know they are included in a full set or a head gasket set. Any ideas?
One last question for this post. I have no problems getting top dead center and alighning the dizzy/rotor, however where should number one position be located as i am looking at the engine from the front? Right now it is at toward the number 2 cylinder. I hope I am asking this clear enough?
Thank you.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
H Online: Content
There is a groove for an O ring on the distributor housing, but since it's in constant motion from the action of the vacuum advance, it would probably wear out pretty quickly. Most of the distributors I've seen don't have the ring there, so I'm going to assume most of them wear and disentigrate.
It doesn't really matter which distributor cap tower is used for the #1 plug wire, as long as the firing order is correct as the other wires are inserted. The correct firing order is 1-5-3-6-2-4 in a clockwise direction. My Motor Magazine service manual shows the #1 position at the cap tower just clockwise from the terminal where the wire to the points attaches.
On my 248 (and any other engine I've worked on) nothing under the distributor, the gasket behind the thermo housing was nothing special, you should be able to make one easily, #1 on my dist. is at about 1:30 as you're looking at the dist. from that side of the engine, so if I'm understanding you, I think you're close. Hope this helps
1955 Second Series GMC
"Done - A 50 Year Journey"
Follow in the DITY
-- No one said it was going to be easy
Chevrolet never used an O ring on the shaft. A lot of rebuilt distributors come with one, but if installed that way will lock the twisting action needed for the vacuum advance.
My Blog
Thanks folks. Appreciate the feedback.
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
I believe #1 should be at about the 5-6 o'clock position.
I could not find a better picture but in this cutaway picture you can see #5 wire. #1 is just before #5 in the firing order. 153624. SHOP MANUAL
Although any position will work if put in time.
HERE IS ANOTHER PIC. Fig #6
My Blog
the thermostat gasket is in the truck shop cat. truckandcarshop.com
The thermostat gasket you can get at any FLAPS.
Pete
Thanks again folks. Just to clearify, I'm looking for the thermostat housing gasket, where it's bolts to the head. I think I can just make one.
Also, I think you are right on the rotor position for number one. Easy to turn and fix. I also have my coil up instead of down. I wonder what the reasoning of facing the top downward? Interesting.
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
I always like the coil mounted with the wires up. I have seen to many coil wires fall out the other way.
My Blog
Dave PM sent
Give me ambiguity
or give me something else
You can get the housing gasket at any FLAPS.
Pete
