2 members (delky, Steelonsteel),
235
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | I just picked up What I think is an Army 3/4 Ton 1941. The id plate has these numbers.
2 5727 Model 9BL41 4990
I would also like to post some pics of what I think were Army ad on parts. Looks like a map holder on the wiper panel and a rear view mirror and bracket. I'll do that later.
Thanks for any help with the numbers.
Trombones Totem Poles And Old Trucks!
| | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Correction.
Chassis number is 9BL41
Model is MASTER
Then in the right lower corner is 4990
| | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | So does anyone know what a "Master" model Chevy truck is?
The only info I have found here leads me to believe thatthe plate is from a 1937???
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Master was the term used for a Chev car series in the 30's and 40's, for trucks it'd be like "AD" or "TF", covers a range of years and sizes .... this tech tip indicates the BL is an early 42 3/4T, with the 9 indicating it was made at Norwood, the 4990 is likely the sequence number Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dan,
Are you able to post a photo of that "id plate"?
Master Deluxe was the name a 1941 car model (Stylemaster and Fleetmaster in 1942).
Load-Master was the name of the 235 engine, which was first available in 1941.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I agree with red58 on the 9BL
9 = Norwood plant BL = 1942 code for a 3/4 ton with standard 216 engine
However, the 41 is not what is shown in the spec manual - those two digits are supposed to be for the month?
Maybe a military truck had some other code placed there?
| | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | It is a military truck for sure. I know that by looking at the paint and the extra stuff on the truck. As a matter of fact it was sold to me as a 42 not a 41. That was my mistake. It has a 235 in it now with a different number, but the title list the vin as H540016129
s\So it is in fact a 3/4 ton?
Is there another location for vin numbers on these trucks? Or is it as I have learned the number on the stamp pad?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there is no other place than the ID tag for a number, and the engine number was never the same as the vehicle ID number - it is in fact a '42 3/4T truck, with a title showing the engine number [of a 54 235] as was common back then - the previous owner who changed the engine no doubt had the vin changed on the title to reflect that change
Bill | | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | Thanks! That helps alot! I did run the casting codes and it did in fact come up as a 53 to 55 235. Too bad it's siezed.
