1 members (klhansen), 153 guests, and 1 robot.
Topics128,126
Posts1,056,356
Members48,441
1 Offline
I just picked up What I think is an Army 3/4 Ton 1941. The id plate has these numbers.
2 5727 Model 9BL41
4990
I would also like to post some pics of what I think were Army ad on parts. Looks like a map holder on the wiper panel and a rear view mirror and bracket. I'll do that later.
Thanks for any help with the numbers.
Trombones Totem Poles And Old Trucks!
1 Offline
Correction.
Chassis number is 9BL41
Model is MASTER
Then in the right lower corner is 4990
1 Offline
So does anyone know what a "Master" model Chevy truck is?
The only info I have found here leads me to believe thatthe plate is from a 1937???
Master was the term used for a Chev car series in the 30's and 40's, for trucks it'd be like "AD" or "TF", covers a range of years and sizes .... this tech tip indicates the BL is an early 42 3/4T, with the 9 indicating it was made at Norwood, the 4990 is likely the sequence number
Dan,
Are you able to post a photo of that "id plate"?
Master Deluxe was the name a 1941 car model (Stylemaster and Fleetmaster in 1942).
Load-Master was the name of the 235 engine, which was first available in 1941.
1 Offline
I agree with red58 on the 9BL
9 = Norwood plant
BL = 1942 code for a 3/4 ton with standard 216 engine
However, the 41 is not what is shown in the spec manual - those two digits are supposed to be for the month?
Maybe a military truck had some other code placed there?
1 Offline
It is a military truck for sure. I know that by looking at the paint and the extra stuff on the truck. As a matter of fact it was sold to me as a 42 not a 41. That was my mistake. It has a 235 in it now with a different number, but the title list the vin as H540016129
s\So it is in fact a 3/4 ton?
Is there another location for vin numbers on these trucks? Or is it as I have learned the number on the stamp pad?
there is no other place than the ID tag for a number, and the engine number was never the same as the vehicle ID number - it is in fact a '42 3/4T truck, with a title showing the engine number [of a 54 235] as was common back then - the previous owner who changed the engine no doubt had the vin changed on the title to reflect that change
1 Offline
Thanks! That helps alot! I did run the casting codes and it did in fact come up as a 53 to 55 235. Too bad it's siezed.
