| | | Forums66 Topics128,165 Posts1,056,989 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Anyone one here ever had headlamp, or fog lamp refectors re-silvered. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | nope, but a low budget buddy of mine used to clean his up and spray paint them with silver paint, sometimes the sparkly metallic kind, then put 'em back together.
You might could test it out on a really bad one...
He also would run the yellow flasher bulbs in the brake lights, they were a lot brighter and kept people from running into him.
-W | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | You could replate at home with a Caswell kit, or contact your local BGT. Big Giant Telescope. Telescope folks like to lay down vaporized aluminum when making mirrors, and you might have luck getting them to do so on your reflectors. I live near The Centre of the Universe and I believe they have a huge onsite vacuum oven to do so. It's an industrial thing though, and you might have a place near you. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Chevy's of the 40's resilvers reflectors but it's pricey anymore. Used to be in Hemmings under "Services Offered" there were several that did this.
Evan
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I simply use chrome paint, let it dry for about 1 hour then cover with clear. | | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | I have seen test where they used white paint in tail lamps next to silver painted ones, the white was much brighter once the lenses were installed. Can you just buff out the steel and clear coat?
Joe | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | My last 2¢ is this. If you ever drive at night, you wan't silver. It's far more reflective. Otherwise your lights will only be useful for identifying objects just before you run over them. | | | | | Joined: Jan 2011 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 20 | I've used semi-chrome from a tube on my fog light reflectors and it made them look brand new. I also bought an aerosol can of M.R.O. Chrome Galvanize Coating industrial 143 from Eastwood for my headlight reflectors and both have worked great. I was really impressed with how well the semi-chrome worked because those reflectors were the worst. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Steve's Auto Restorations in the Pacific Northwest does it. | | |
