3 members (Gdads51, Bill Hanlon, Otto Skorzeny), 65 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#831377 03/01/2012 11:40 PM
1977 chevy stepside. I swapped out the 305 and original 400th trans and put in a 350 350th trans. ( BE CLEAR I HAVE NEVER DONE THIS MUCH BY MYSELF BEFORE) engine runs great trans shifts smooth but wont gear down. I put on an edlebrock performer intake and a holley 900 4 bbl carb. I had to add a bracket for the throttle cable and trans cable that came with the carb kit. do i need to adjust the trans cable or am i missing something?? any and all suggestuons welcome. Paul
The cable should be pulled all the way out when the throttle is wide open. That's the adjustment for the kick down cable. Also be sure you have a vacuum source for the modulator,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
The only function of the cable on a 350 is for kickdown. Just as the throttle reaches wide open, the cable should reach its full travel. Shift points on a 350 are controlled by the modulator and the governor pressure, which is generated by the speed of the driveshaft. Adjust the kickdown cable to be full forward at wide open throttle and it should function. If it doesn't, there is an internal problem with the kickdown band and/or the servo that applies it. That's overhaul territory!
