4 members (NJC, Dusty53, 37 GC, Shade Baby), 137 guests, and 2 robots.
Topics128,141
Posts1,056,780
Members48,454
So, as I have the tank off to clean out the crap that keeps clogging the fuel line, and to see what's going on with the sender, I'm struck by just how small the tank is. I haven't done a liquid measure yet, but uh..... It looks to me like its only about 12 gallons or so. How am I going to run interference for the Snowman if I have to keep stoping for gas?
Also, as you can see, my sender is a bit "frozen". Dang.
http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP2283.jpg
http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP2281.jpg
http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP2282.jpg
http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP2285.jpg
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr Lang,
That's the correct tank. I'm sure someone who has an original tank will come along and tell you the capacity. I put a tank between rear frame rails where the spare tire used to be. Drawback is no spare and I have to wait on AAA.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
the tank will be 16-18 gallons like all GM trucks back then - measuring it out: inchesX inchesX inches / 231 = gallons .... or about 7.5 US gallons/cubic foot
Here is some information on the 1947/1955 SUBURBAN/PANEL/CANOPY EXPRESS GAS TANKS
Fantastic link. I guess it must be 16 gallons then. Other than the dents...
It just looks so small when its out from under the bus.
Thanks. I guess I should have used the search feature.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Yep, we been through this before. I almost took a gallon measuring tank and filled up one of these....
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Fueltanks002.jpg
but rather than to the work I decided to accept the fact its a 15/16 gal. tank....I suppose it depends on how much you can pack in it including the filler neck!!!
Yeah, I guess if I want to get 16 gallons in there, I'd better shake the truck back and forth, to make sure the filler neck is full! My gauge should work now, so that should mean I don't run dry anymore......
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Mr. Lang,
When I fill up, I can never get more than about 13 gal in the tank, and this is when the needle is at the point that I know, from experience, that I am about dead empty.
Kurt
Whwn you get it together, put in several gallons. Make sere you have a spare 1 gallon can. When you run out, put in the spare 1 gallon and head for the closest station. When you fill it up, you will know how much gas you have avaible for driving. This is really what's important. Not the tank capacity. You have some at the bottom of the tank you cannot use.
Filler and keep on trucking
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
I've got 5 gallons in a jerry can here, to do just that! My tank pick up will suck the tank dry, not even a cup of gas remains! I guess the tank is dented in all the right places. I had to suck the tank dry, as my tank drain has been soldered shut.
Looking at the bottom of my panel, seeing the dents in the gas tank, the four holes repaired in the oil pan, I've come to a conclusion. It must have been featured on an episode of the Dukes of Hazzard. Perhaps Bo and Luke drove it up the old creek bed in order to escape Roscoe P. Coletrane.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
That looks just like the tank on my '48 3100, which is 15 gallons.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Tom,
This says 16 gallons in 1948; and, it also says that all 3100 1948 gas tanks were the same size (probably the same tank in regular cab and panel-body).
16 gallons here, too; and, my interpretation might be incorrect, but that 16 gallon between-the-frame tank was used in panel-body trucks through 1953. Regular in-the-CAB 49-53 tanks were 17.5 gallons.
Like Chris says. The tanks can be sucked dry. My old one was rusted out so bad it was pitiful....however you can see how the "pickup" tube is tacked to the bottom of the tank, I could also see this in two other tanks of which one was a new one.
check this pic.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Fueltanks004.jpg
as a footnote, the babble is just about 4 inches back from the pickup tube. It sits up about 1/8 inch off the bottom of the tank so no gas is "caught" behind the baffle.
Awwwh Alvin, you're an alarmist. That looks like all it needs is "Por 15" .
Well, maybe you might want to look for Por 16. It's one more isn't it?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Just as an update, my tank in fact, holds 10 gallons. That's all I can get in at the gas station. I imagine my vent tube is pointing down, and not against the top of the tank. When I replace the fill hoses, I'll look at that. At least it's clean, and the gauge works now.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
