7 members (jmoore, kades51, Otto Skorzeny, TexasA&M48Truck, Frank50, Jon G, 1 invisible), 74 guests, and 1 robot.
Topics128,132
Posts1,056,379
Members48,441
V
V Offline
Hello all,
I have a '57 Chevrolet (car) with a 235 straight six. I just installed a factory overdrive and love it but because of the free wheeling option it means I come up to red lights as though I have my foot on the clutch the whole time.
When I come up to the red lights this way the car wants to die. It will start back. I think perhaps the carb (original 1 barrel) needs some adjustment. Does anyone have a good description of how to tune one of these carbs? I don't know much about how to set up a carb.
Brandon
here'a a manual, that covers the operation of the OD in the transmission chapter, and also the carb, if it does need attention
I don't like red lights either
V
V Offline
I think the 55 used a different carb. I guess it would still be the same basic operation though, right?
Brandon
the manual linked is for the 2nd series 55-59 truck, any differences from the 57 car will be trivial, transmissions are near identical and carb function the same
V
V Offline
Alrighty. Thanks
Brandon
I had the same problem in freewheeling mode when coming to a stop. I found my idle mixture set too lean. I adjusted the idle mixture slightly richer to solve the problem.
